Re: Starter
Posted by Owen Aaland on April 25, 2009 at 23:25:25 from (65.165.246.54):
In Reply to: Starter posted by Paul G. In Mn on April 25, 2009 at 18:56:56:
They will interchange though originally some H starters did not have the center armature bearing. I have only seen a couple like that and I added the bearing to them. There are some after market starters that have a drive end housing that do not have the recess and threaded holes to add the bearing. They can cause problems on an M or a high compression H by bending the armature enough to rub while cranking. If you stick with a starter with a Delco tag you should be fine.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
