I was working on this tractor with Al yesterday and .015 is at the (rear) output shaft bearing, out at the 4/5 gear end of the output shaft there is .125 worth of play. I'm suprised it ever even went into 5th. Thanks for the reply, from what I see, remove the pump and clutch shaft and slide the output shaft forward after removing the bearing supporting the belt drive gear. The belly pump seems straight forward, remove the cotter pins and the driving shaft should come out. Then support the pump and remove four bolts and it should drop out. Let me know if it seems like I'm missing anything or any more tips what to replace/inspect while we have this much torndown. Thanks in advance.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
