Re: WD9 help
Posted by tractorsam on April 26, 2009 at 07:00:40 from (142.177.22.181):
In Reply to: WD9 help posted by stewartinpa on April 26, 2009 at 05:50:51:
To bleed the system you need a full tank of fuel. With the engine off bleed any air out of the fuel bowl and the rearmost filter. Start the engine, bleed the front filter. Then open the diesel throttle a bit and crack the small bleed screw on the back side of each injector until you have solid fuel coming out. Be very careful doing the latter as you are dealing with high pressure fuel and you don't want to inject it under your skin. There is a small hole the fuel will come out of, take note of this before you start. Good luck, Sam
