Re: GAS OR DIESEL
Posted by I.H.parkingonly on April 26, 2009 at 09:10:29 from (24.183.3.246):
In Reply to: GAS OR DIESEL posted by FARMERDAVE on April 25, 2009 at 20:28:48:
A 656 gas hydro will be very hard on fuel, It would be more economical to run a deisel. I would"nt have a hydro myself, Way to expensive to repair. I guess I would see if it slips at all, I know some guys replace the hy tran fluid with gear oil or something thicker when the hydro starts getting weak , so check for that.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
