Re: schwartz wide front
Posted by ChasinPA on April 26, 2009 at 10:05:25 from (96.247.154.96):
In Reply to: schwartz wide front posted by bbaro on April 26, 2009 at 07:20:57:
The Schwartz front end will fit with some adaptations. We changed one from an H to an M. You may have to drill some new holes in the plates that bolt to the frame. May also need a cutting torch and welder. Not big changes but basic fitting to the smaller frame.
