H with 31 loader
Posted by B T Riordan on April 26, 2009 at 10:43:23 from (70.129.227.102):
I drained the oil (and water) out of the pump on the 47 H. Put in 6 qts of non-detergent oil and now it won't lift the loader over 2 feet! So I thought I'd better check with you-all before I screwed up anything worse. Do I need to put in additional oil to compensate for the volume of the cylinders? Put the water back in? If more oil is needed, how much should I add? Anything else this could be? What do you-all think?
Thanks!
