ky's 861: There must be some hydraulic plumbing crossed between control valves and cylinder. Given the fact two different levers will raise it, I suspect one control valve it hooked to each side of cylinder. Then you have the fast hitch tele-a-depth control, which should control the hitch, however many of them no longer function as intended. Then you have the possibility the tele-a-depth control is connected and the draft control is unhooked or damaged.
I would suggest someone has had problems with the tele-a-depth control valve, did a plumbing nightmare trying to make it work without money, then gave up. You'll have to follow the plumbing from the cylinder to the control valves, be sure both lines are connected to the same valve. If the problem is the tele-a-depth control it either has to be repaired or replaced by a standard control valve. You can't just not use a tele-a-depth control valve, it either has to be working and coupled to the hitch or it has to be removed.
I know this sounds like a nightmare, but you are dealing with a nightmare.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
