Posted by Steven f/AZ on April 26, 2009 at 16:34:32 from (24.121.133.155):
In Reply to: schwartz wide front posted by bbaro on April 26, 2009 at 07:20:57:
I swapped a Speeco wide front from a 450 to an H...
The main 4 bolts to the lower bolster casting are the same from an H up through a 1256 (I've measured). The rear supports to the frame rails will be different as the SMTA is wider than the H.
The steering arm bolt pattern is different, as well. I just used a torch and slotted out the holes from the 450 arm to fit my H (cheapest solution). I vise-gripped the H lower bolster to the 450 steering arm and slotted the holes to fit.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
