Check that the front of throttle tube is free to move to where it wants to end up after mounting to carburetor.(not binding in governor housing and cocking it) You may have a height problem that results from material removed from head surface, or poor fitting manifold. Some aftermarket ones used to be bad on that. Also tube may not center the throttle shaft exact in center on carb end and be cocked a little in new bushing. Sometimes spining tube 180 degrees will help. Also try stopping just short of tightening the 2 throttle shaft screws all the way and move end of tube to see if there is a place shaft is more free. If so you may have to give a little more clearance at bushing.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
