Re: diesel SMOKE
Posted by William Chavis on April 26, 2009 at 18:33:14 from (205.188.116.73):
In Reply to: Re: diesel SMOKE posted by JimB2 on April 26, 2009 at 18:04:51:
Thank each of you for the feedback concerning the B 414. I think I have mentioned I have a IH 444 that is similar to the B 414. In fact, that is tractor where I got another injector to verify the one on the B 414 was faulty. I have since put it back on the 444 and undecided to continue trying to salvage the B 414 as an operational unit. The PTO will not engage running or not running? The hydraulic ports mentioned by several is exactly like that on the 444 which I have set the ports in that order. As for the filter, I plan to check that tomorrow. It don't look good from all that I think I know about both the PTO and 3 Pt lift. I most likely will begin parting it out as a result. Probably get 10 more years on my old IH 444 with some of the good parts on this unit??? THANKS TO ALL.
