Posted by D Slater on April 26, 2009 at 18:41:24 from (71.164.42.190):
In Reply to: Farmall md posted by Jay Snyder on April 26, 2009 at 17:54:12:
Short answer if you adjusted all valves and linkages to spec when the head was installed its just like a regular gas engine after that. If it has good spark at the correct time, fuel and compression it will run on gas. If linkages were not checked you may have intake butterflies not moving, starting valves not opening and the magneto could be grounded out.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
