Re: float level for F-14 carb
Posted by James Williams on April 26, 2009 at 19:24:55 from (170.215.130.81):
In Reply to: float level for F-14 carb posted by lil mac on April 25, 2009 at 07:20:43:
Remove the plug at the bottom of the carb bowl,screw a barb fitting in the hole with a peice of clear tubing atached to it to determine the fuel level.The fuel level should be half way up in the bowl
jimmy
