Re: Why does my loader not stay up?
Posted by John G. Hasler on April 27, 2009 at 05:07:01 from (64.91.34.95):
In Reply to: Re: Why does my loader not stay up? posted by BlakeinTN on April 26, 2009 at 19:25:53:
> If the cylinder is allowing fluid to pass around
> the packing on the piston, the fluid simply
> moves from one side of the piston to the other,
> allowing it to sink back into the cylinder.
As the piston sinks into the cylinder the shaft follows it, taking up some of the space formerly occupied by oil. Draw a lengthwise cross-section of a fully extended cylinder and a fully retracted one. Compare the two drawings and it will be obvious that there is less room for oil in the fully retracted one. Thus in order for the cylinder to retract some oil must leave it.
