Re: IH 300U Overheating
Posted by Matthew Williams on April 27, 2009 at 06:03:28 from (208.195.70.39):
In Reply to: Re: IH 300U Overheating posted by CCer on April 26, 2009 at 03:47:13:
Any way to easily tell if it has come lose? Also how do you checck if there are hot spots on the engine or radiator short of touching them?
Sounds like I just need to take it all apart and clean it, the fluid looks good but I haven't done anything else. Given the symptoms I would guess that the impeller came lose but I don't understnad why it would overheat if the coolant isn't being pumped around, seems like it would sit in the radiator and the engine block would get too hot.
Thanks for the help! I was looking for a magic solution that would save me doing the work. :)
