Re: Generator 6 to 8V
Posted by MHMalcolm on April 27, 2009 at 06:06:31 from (66.66.148.252):
In Reply to: Generator 6 to 8V posted by pete_5959 on April 27, 2009 at 05:09:06:
You don"t have to do anything to the generator. You will have to close the current relay point gap in the regulator until you get a plus charge reading on your ammeter while the engine is running, about 5 amps max so you don"t over charge the battery. It should be reading in the negative now. If your H has a distributor, you may find your points will start pitting sooner than usual because of the increased voltage, also any lights on the tractor will be OK, but may burn out quicker, also because of the increased voltage, especially if they are the originals.
