The lever with no rod, with two holes, is the control lever for a belly pump, which is inside it's reservoir inside the clutch housing. You can take a sheet metal plate off the bottom, directly under the belt pulley, and look at it from the bottom.
The fill cap is up and to the right, just in front of the bottom of the gas tank. The normal fill point for a belly pump is right under the hydraulic valve.
It looks like you have Super M brakes (cast housings) so this may be a Stage I, disc brakes with belly pump, but I thought the hydraulic valve you have was with the live pump in front of the distributor. Things may have been changed over the years.
The belly pumps had dipsticks to check level, through the fill hole, but not with your setup. The drain plug will be visible from the bottom.
All major castings have date codes, month*day*year except the year is a letter. You might look at the axle housings, transmission, clutch housing, etc. and see whether most of the dates are close together. It is possible you have a newer rear end on an older front end. It does not really matter, but it will be easier to work on things if you know what you have.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
