Posted by John T on April 27, 2009 at 07:27:12 from (66.244.97.31):
In Reply to: Generator 6 to 8V posted by pete_5959 on April 27, 2009 at 05:09:06:
Since you already bought the 8 volt battery, not much good in trying to convince you otherwise, that being said:
If you have a Cutout Relay and LHBD light switch charging system, it should charge an 8 volt batetry with NO changes, it may not set the world on fire but ought to keep it charged......
If you have a Voltage Regulator with ONLY a current control relay/coil (NOT a voltage control relay/coil or a current/voltage combo) it can still charge an 8 volt battery unmodified.
HOWEVER if your VR contains a Voltage Control relay/coil it would work better if adjusted..
Theres a lot of different VR's floatinG AROUND OUT THERE Id just GIVE IT A TRY N SEE WHAT HAPPENS.
If its a coil ignition ideally you would want to add around 0.5 ohms of series voltage droping (8 to 6) external ballast so the points last longer n the coil dont run over warm butttttt Ive seen them work with no ballast added, although the points will burn up a bit sooner. Similar the lights will glow brighter but burn up sooner.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
