Re: Super M Hydraulics - please explain
Posted by D Slater on April 27, 2009 at 08:09:34 from (71.164.40.115):
In Reply to: Re: Super M Hydraulics - please explain posted by Asbennett on April 27, 2009 at 07:03:01:
You have the transmission driven hydraulic belley pump. Looks like lever on side of housing is locked back in constant pump mode. The valve on top is for 2 way cylinders when 2 hoses are installed and the lower lever is locked back to use it. Openings on side are for pressure in and out the same hose, operated with lever on side of housing. This all depends on drive coupling to pump in place and pump working. They didn't put live hydraulics on all later SM tractors, so you could have a 54 model. If it has a 3 bolt starter mount its probably a stage 2 without live hydraulics. Battery box under seat and belt pulley lever to left side indicates it is a stage 2.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
