Re: Repairing carb on Super M - where does the litttle ba...
Posted by Bob M on April 27, 2009 at 09:11:50 from (151.190.254.108):
In Reply to: Repairing carb on Super M - where does the litttle ball go? posted by asbennett on April 27, 2009 at 08:32:05:
Sounds like the choke shaft detent ball. (It helps hold the choke in the open position). It lives in a hole drilled in the carb bowl at the throttle shaft bushing.
In addition to the ball there's also a small spring that goes in the hole and pushes on the ball. The ball and spring can be a bugger to assemble - make sure your workbench and the floor beneath are clean so you can find the parts if they get away from you(!)
