Have you checked to make sure the fuel cap is vented?
Hook a plastic U-tube up to the carburetor drain so you can monitor the fuel level in the carburetor while it is acting up.
I had a C once which had a ring of fuzzy debris (I accused my help of using a stick to check gas level) which would float around in the gas tank causing no problem until it decided to get sucked around the fuel outlet and just about kill the tractor. Then with no load it would float away and the tractor would run great, for a while. We only found it after draining the tank through the carburetor. We missed it turning the tank upside down twice. It may have been gasket material.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
