Well did ya set the end play on the T/A???? did ya shim the bottom shaft??? did ya get the slack out of all the bottom shaft gears and spacer???? Did ya tighten up the bottom shaft and drill and pin it????? I would say that ya did not get the slack out of the bottom shaft . After ya redo a couple form a screw up you will learn . They are not as easy to get wright as one thinks . heck i even messed up one myself by getting in to big of a hurry and got to tear it all back down AFTER I JUST PAINTED IT . just to turn one gear around . So pull it back in and take it all back apart and set the end play and use the same thickness shim on the bottom shaft as what you shimmed the quill bearing housing. Then when ya do the bottom shaft ya tighten up the lower shaft nut TIGHT then give it a couple good raps with a BMFH and brass drift and tighten again then back off and snug up then drill the nut and install a 1/8x1/4 rolled pin through the nut and bottom shaft. . Also look over your gear and make sure that they are facing the wright way.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
