Re: 2424 Question
Posted by JimB2 on April 27, 2009 at 19:46:29 from (99.240.236.11):
In Reply to: 2424 Question posted by Edward M. on April 27, 2009 at 19:19:01:
Hi Edward, the 424 is based on the frame from B275 and B414. Trans and Diff are all same 80 or 90wt gear oil. There are at least 2 drain plugs, one on bottom of diff case below PTO, the other is on bottom of transmission. Filler plug is by gear shift, level check plug is on side of transmission case by foot rest. Can't remmeber if it is on left or right side.
The Hydraulics use CaseIH Hytran hydraulic fluid and is filled from plug behind seat. To drain the suction tube must be split at the join by gear shift lever.
Hope this helps
JimB
