Note: #1, 2, & 3 adjustments are done with the engine not running when the carburetor has been removed & replaced. 1. Loosen the 2 screws that are holding the governor tube to the governor housing. The clamp is slotted to allow adjustment. Tighten the tube-to-carb screws; gently tap the tube so it "centers" itself, & then tighten the tube-to-governor screws. 2. Remove the top cover on the governor housing (has the pipe going to the cylinder head) and check governor to carburetor synchronization. Remove the cotter pin so the clevis pin can be removed. With the operator's throttle lever set wide open and rotating the horizontal rod upward to wide open throttle position, the clevis pin should just slip into the rod that is in the tube. This horizontal rod should rotate freely allowing the carburetor throttle plate to move from idle to wide open. Adjust the clevis height if needed & lock the nut. You may need small fingers & right-angle needle nose pliers to make the job easier. Return throttle lever to idle. Re-attach the top cover. 3. Carb adjustment: idle air screw is set at 1½ turn out to start with; high speed mixture screw is 2½ or 3 turns out. 4. With the engine warm & running at wide open throttle (WOT), turn high speed mixture screw (on the bottom facing down to the rear) in until the engine begins to starve for fuel. Then turn the screw out until the engine begins to blubber. Now find the "sweet spot" in between the two settings. If you are working the engine (plowing, etc.), then the high speed screw needs to be turned out ½ turn or more beyond the "sweet spot" to be sure the engine isn't starving for fuel and can develop its rated power. 5. The same procedure can be followed for idle mixture with the addition of setting the idle stop screw (just to the rear of the governor shaft tube) to adjust the low speed RPM. On the "H"& “M” carb, the idle mixture screw (faces to the front just below the idle stop screw) is an air adjusting screw so turning in will richen the mixture and out will lean the mixture. Repeat the carburetor adjustment procedure again to make sure “all is well”.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
