Posted by glennster on April 28, 2009 at 06:12:06 from (75.57.116.97):
In Reply to: cub in a barn posted by archie3 on April 28, 2009 at 06:01:30:
couple things i'd do. 1- drain the fuel tank and flush it 2-drop the carb bowl and clean it out good, blow out the fuel lines. 3- pull the spark plugs, couple squirts of automatic trans fluid in each cylinder, roll the motor over a couple times. drain engine oil, check for antifreeze or any creepy looking stuff in there, if ok, refill with fresh oil and change filter. 4- check coolant and belts. 5-pull distrubutor cap, inspect points, maybe shine em up with some 320 grit sandpaper.
crank the motor over and check for spark. if you got spark, button everything up and see if she starts. watch the oil pressure real close if it fires up. the pump can loose its prime.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
