This is a goo point about the hydraulics getting hot. My 450 used to have this problem. I would the oil with the engine running and fluid poured out of the fill hole. The piping would get far too hot to touch.
Eventually found the single- double- acting selectors for the valves were set halfway between, creating a constant full pressure load on the pump. After I fixed all this, it was only then I discovered the power steering didn't work...
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
