Re: MD cracks, critical or not?
Posted by the tractor vet on April 28, 2009 at 10:49:42 from (75.19.124.161):
In Reply to: Re: MD cracks, critical or not? posted by 26Red on April 28, 2009 at 10:08:15:
Well i know that there are some .020 out there and that is the route you might have to go .I would give Clyde Burkshire a call and talk with old Clyde . As for the block if it is welded welding will distort it and then you will have to line bore . I think i know a little more on engine building then most . With getting on near fifty years of doing it. Find a nother block , check the cylinder bores for cracks and deck surfaces and you already know about the bottom . If ya can only find a block that is cracked down in the bore and the crack runs up and down don't panic they are the easy fixes . Ya just bore that hole out install a heavy wall repair sleeve and rebore the repair sleeve and put the sleeve in all fixed .
