Re: No Cub Oil Pressure!
Posted by Janicholson on April 28, 2009 at 17:51:20 from (71.87.46.76):
In Reply to: No Cub Oil Pressure! posted by Don Mountain on April 28, 2009 at 17:31:21:
There is a socket head setscrew looking plug behind the oil filter that leads into the oil gallery. Use a pump type oil can with a rubber chunk of tubing, to adapt it to the hole, to pump the thing full of oil. (it might take several cans, but it will precharge the system an assist to catching prime. Cub oil pumps live in the block, and cannot be removed as a unit. JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
