Re: cleaning up anti-freeze and oil from engine.
Posted by Chuck's Repair on April 28, 2009 at 17:52:02 from (162.40.106.165):
In Reply to: cleaning up anti-freeze and oil from engine. posted by red until dead on April 28, 2009 at 13:50:36:
There is a special solvent that you add to the engine oil then run at low idle no load for about one half hour as I recall.You then change the oil and filter and run for another half hour and change the oil and filter again. I don't remember the name of the solvent. It had a long name. International Harvester had a service bulletin on this procedure I believe it was in the early 1970's. Changing the water filter and adding a coolant conditioner at recomended intervals will prevent the cavitation.
Chuck
