Posted by Haas on April 28, 2009 at 18:02:54 from (12.65.48.224):
In Reply to: Farmall md posted by Jay Snyder on April 26, 2009 at 17:54:12:
Does it blow air cleaner oil out the intake when you try to start it?? If so, you may have the mag 180 degrees out of time. Remember, there are only two cams on the points rotor, and 2 to 1 gears between the cam and the distributor. To fix this remove magneto and turn the drive 1/2 turn and reinstall.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
