Posted by billde on April 28, 2009 at 20:34:27 from (72.26.89.156):
In Reply to: No Cub Oil Pressure! posted by Don Mountain on April 28, 2009 at 17:31:21:
Don Mountain said: (quoted from post at 17:31:21 04/28/09) I have an older 1950"s International Cub LoBoy that I use for mowing the grass. On startup this spring, I backed it out of the barn and saw no oil pressure on the gauge, so I shut if off. I have never had this problem before. I checked the oil as it was changed at the end of last year, and is up to the full line. It also had a new filter with only a few hours on the oil and filter. I remember hearing somewhere about the Cubs having a hard time priming the pump after they sit for awhile. How do I reprime the system? Can I take the top off the oil filter and fill it up from there? I don"t see any plugs or any way to get into the oil gallery?
Don Mountain
Inside the oil filter housing there is a hole on the block side, pump heavy oil, 30 wt will do, into the hole with a pump oil can. Pump until pressure is built up, quickly replace filter, replace top of filter housing and start. Watch the oil guage. Repeat if necessary.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
