Jesse: As Allan told you earlier you will love those duals for disking, same with field cultivator.
You probably want to keep the chloride for plowing, and your right lot less weight than 20.8x38. If your run duals much, chloride in one set will cause tires to wear at a different rate. I can tell you that within months of changing my 1066, I did the same with my 560 on 16.9x38, dumped chloride and went duals. I also dumped chloride in my 656 again 16.9x38 however I did not dual that one as I used it for drilling, planting, haybine, spraying and plowing. I did keep the chloride in Farmall 300 with 13.6x38, why you may ask, because it hauled wagons on hard roads, and it takes chloride to make a 300 as heavy over rear wheels as a 560 or 656 without chloride.
The old single wheels with lots of weight are still best on hard roads or frozen ground. One of the merriest tractor rides I ever had was 1066, on duals, with a 12 ton manure spreader pushing on frozen ground.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
