Re: H and M Oil Filters houseings
Posted by nebraska cowman on April 29, 2009 at 05:24:15 from (98.16.149.188):
In Reply to: H and M Oil Filters houseings posted by Paul G. In Mn on April 28, 2009 at 18:17:20:
The 39 M uses a filter that is larger diameter and about the same height as the tall H filter. This is the same as the later Ms used as well as the hundred series tractors. Later Hs used a shorter filter. Are you confused now? OK the F12 F20 & F30 also use the tall skinny filter as your H. The 39 M filter will fit a W9. And yeah, the skinny filters, tall and short, will interchange by changing the can.
