Re: Farmall M propane conversion
Posted by nebraska cowman on April 29, 2009 at 05:37:04 from (98.16.149.188):
In Reply to: Farmall M propane conversion posted by Stevie J. Mote on April 29, 2009 at 05:19:53:
Several companies made conversions. There shold be a name on the converter. Century is one that I see. IH sold Ensign. The Century used an aluminum bowl on the bottom of the existing carburetor. Ive seen cast iron gasoline carbs converted by simply drilling and tapping in the line. Some say start on vapor the switch to liquid for power. I leave both valves open all the time. If it floods it may start better leaving the throttle closed. You will just have to play with it and see what works best. If you turn on the gas and hear it hissing the diaphram is out of the converter and you will have to rebuild it.
