Posted by rustyfarmall on April 29, 2009 at 08:11:10 from (209.152.78.140):
In Reply to: '48 Farmall H posted by Worker bee on April 29, 2009 at 07:58:50:
The first thing to do is take out the spark plugs, shine a light in the hole and see what you have. If the cylinder is full of water, try cranking the engine again with the spark plugs still removed. If it was hydro-locked, that should cure it. If it is not hydro-locked, but instead is rusted, (most likely) spray some penetrating oil such as PB Blaster, or pour some automatic transmission fluid into the cylinders, let it set and soak for a couple of days and then try cranking the engine again. If the tractor sat outside for only 2 weeks, it shouldn't be too hard to get it unstuck.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
