Re: 340 international utility with clutch problems
Posted by old on April 29, 2009 at 10:45:13 from (4.245.5.186):
In Reply to: 340 international utility with clutch problems posted by HerbF on April 29, 2009 at 09:19:55:
Sounds like it just plan needs to be replaced if adjustments do not help. The more you try to use it as is the more likely it is that you will mess up the flywheel face and then have to have it turned if it doesn't already need it
