Posted by ScottyHOMEy on April 29, 2009 at 15:08:21 from (70.105.244.253):
In Reply to: farmall super c gas posted by mitchfarmallsuperc on April 29, 2009 at 13:30:10:
If it's right under the fuel tank, that's what's called a sediment bowl. The float bowl is the bowl of the carburetor.
They're pretty readily available through most parts outlets.
It's sometimes hard to tell where the leak is coming from. It could be the thread between the bowl assembly and the tank but usually isn't. More common is for it to be the gasket between the glass and the meatal, or around the valve stem.
Before going looking for a new one or a gasket, you might try just tightening the compression nut, which is the hex nut that would appear to surround the stem (the part you're turning) of the valve. It won't go far or take much, and you may find that all you've accomplished is to make it so tight that you can't turn the valve and that it still leaks. If that's the case, you can learn how to repack the valve (quite simple actually and a neat little project, and while you're at it would be a good time to replace the bowl gasket and the screen inside the top of the bowl) or go ahead and thread a whole new bowl assembly in.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
