With the cable disconnected at the pump, can you still get high idle and shut off? If not, the problem is with the pump. If it works ok at the pump the problem is with the cable and linkage.
Make sure that when you move the throttle linkage that you have enough travel to go past the throttle stops on the pump. With the pump lever pulled back it needs to move past the point where it just contacts the stop but also causes the lever to pull against the spring assembly. The same with shutting it off. The lever needs to move past the pint where the shaft stops turning into the pump and goes forward against the spring.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
