Re: John T - Starter motor question
Posted by Owen Aaland on April 30, 2009 at 03:55:13 from (65.165.246.54):
In Reply to: John T - Starter motor question posted by Cedric on April 30, 2009 at 02:36:34:
Even if you rewired the starter to run in the opposite direction, the spiral on the armature shaft will be wrong. It will move the drive in away from the ring gear when it starts to turn.
