Re: cub in barn part 2
Posted by James Rumph on April 30, 2009 at 04:59:53 from (24.192.125.175):
In Reply to: cub in barn part 2 posted by archie3 on April 29, 2009 at 18:17:44:
It depends on the year ! On my 54 and 55 you adjust it on the clutch pedal.
On the bottom of the pedal there is a bolt in a slot you loosen and move tell you get what you need.
I wish i could tell you more but everyone will be differnt.
There is on the older ones a adjustment underneeth in the bell housing that does the same thing. Remember the throw out bearing has a zirk fitting so make sure it has some lube.
Your just adjusting the movement of the throw out bearing as far as engagement and disengagement of the clutch.
Lets hope it just needs to be used due to its time sitting.
Three years ago a gentelmen told me he had a 54 that has been stored in a barn for 30 years, "sure you do". He did and i bought it, the motor wasnt stuck but the valves were.
I had to rebuild both bull gears due to leaks and free the valves other then that it is mint for it"s age. It still has the orignal seat "perfect" the orignal tires "perfect" and the trans is dead silent unlike so many others.
I wish you luck on your project.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
