Re: 460 U Cultivators Need help?
Posted by IaGary on April 30, 2009 at 06:24:37 from (199.120.96.231):
In Reply to: 460 U Cultivators Need help? posted by Lostcause101 on April 30, 2009 at 05:53:01:
As Jim stated the only cultivator I have ever seen on a utility was rear mounted on the 2 pt or 3 point.
If you have a front mount cultivator it is most likly for a row crop IH.
The wheel base with the wide front is to short for a front mount on a utility.
Gary
