Re: John T - Starter motor question
Posted by Bob M on April 30, 2009 at 07:49:54 from (151.190.254.108):
In Reply to: John T - Starter motor question posted by Cedric on April 30, 2009 at 02:36:34:
Cedric - To reverse starter rotation, the brush connections must be rotated electrically 90 deg releative to the fields. 2 ways to do this:
1 - Rotate the commutator end plate 90 deg from its present position (Which direction doesn’t matter)
It’s not easy to accomplish. New holes for the thrubolts are required in the end plate, a new hole located/drilled for the commutator plate locating pin, and the field conductors (copper straps) repositioned/reconnected to the insulated brush holders. It also now puts the end plate bushing oiler in an odd position.
-or-
2 - The field shoes/coils can be removed and reinstalled inside the frame rotated 90 deg. Again this requires repositioning and reconnecting the copper field straps to the insulated brushes.
Of course you need the a new bendix for the opposite rotation – which you’ve already done.
Were the starter mine I’d take it to an old time starter/alternator shop tell them what you need, and let them rework it. Alternatively I'd sell the starter you’ve got and use the proceeds to help pay for a rebuilt “correct” starter for your W-4.
