Re: Cub cadet Snow blower
Posted by gene bender on April 30, 2009 at 10:33:46 from (67.55.227.59):
In Reply to: Cub cadet Snow blower posted by New to MF Peter on April 30, 2009 at 09:31:31:
Take the old gear out then get hold of a BROWNING dealer and they can get you a new one. You need the size amount of teeth and shaft size. Probably can order on-line just need all the info gor the gear.
