Re: Exhaust Manifold Repair on a Farmall 400
Posted by Andy Martin on April 30, 2009 at 10:50:07 from (199.197.2.142):
In Reply to: Re: Exhaust Manifold Repair on a Farmall 400 posted by the tractor vet on April 30, 2009 at 10:00:03:
If you want to weld it, get everything cleaned up, start the engine and get the manifold hot. Kill it, weld it, and restart it to get it all good and hot again. I've done several this way and none have cracked. I use Ni-Rod.
