Re: Exhaust Manifold Repair on a Farmall 400
Posted by dhermesc on April 30, 2009 at 11:28:39 from (24.248.193.103):
In Reply to: Exhaust Manifold Repair on a Farmall 400 posted by Ron Turchin on April 30, 2009 at 09:48:19:
Rethreading the pipe might work - I tried that with a 656 and 350 - it worked for a while on the 350 and didn't work at all on the 656. On both tractors the pipe had wobbling back and forth for years (decades?) and had worn out the inside manifold so there wasn't enough left make threads that would hold - even with "fresh" threads on the pipe.
Eventually I replaced the manifold on both tractors.
