Re: Seal Replacement
Posted by NC Mike on April 30, 2009 at 13:30:41 from (70.144.172.46):
In Reply to: Re: Seal Replacement posted by Andy Martin on April 30, 2009 at 12:54:32:
I think the bushings are good. Every thing is very tight. The bearing on the end of the steering shaft was replaced at some point and was leaking oil and they placed grease in the gear box. The lower bushing seems tight also. The thrust bearing is bad, It's flat spotted. You would never know it by how well the steering worked. Very little play in the steering and no wobble in the tires. This all started by fixing all leaks and getting every thing back to factory specs for a show tractor
