Posted by pete 23 on April 30, 2009 at 18:18:42 from (173.87.1.12):
In Reply to: Seal Replacement posted by NC Mike on April 30, 2009 at 12:04:39:
The thing about installing any seal is the driver must be very close to the exact size of the outside diameter of the seal and it must have a square shoulder. If it is not you will for sure deform the seal. I have a driver for an H and use same one on the M by using a heavy washer over my driver that fits the seal and just use masking tape to build outside diameter of pilot to fit into the bushing. . It pilots up into the bushing so as to keep you on track while driving seal in. The top bushing will have very little side play if good and shaft must be smooth. Don't use gun grease as it cannot lube shaft and then it will wear. We used to use the torque amplifier additive in steering gear boxes and it worked great but you cannot get that any more so use a good EP heavy gear lube.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
