Posted by JeremyG on April 30, 2009 at 19:05:06 from (65.1.101.241):
Grandfather has a 41A that is stuck in 2nd gear. You can push the clutch in and move the shifter forward and back. It will go forward if you push it back and not go anywhere if you push it forward. I have not seen it yet but he was messing with it today and got fed up. I do not think he took the cover off yet below the shifter so who knows.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
