Just start out lightly snugging the center bolts first and the swap sides till you get to the ends, then start back in the center and tighten then up good and work to the outside like before. If you use a 3/8 ratchet tighten up good and tight, and if a 1/2 ratchet just tight. Run for a bit to get hot and redo the whole process. You will want them all the same tightness so if you use a torque wrench just make them even. I know of no correct spec.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
