Re: 800 planter firming points
Posted by Brownie 450 on May 01, 2009 at 03:40:24 from (216.51.158.151):
In Reply to: 800 planter firming points posted by Mark in C.C. on April 30, 2009 at 19:12:28:
Remove the left-hand coulter on each row to make the job easier. Use a cold chisel to loosen up the hub cap & then a pump pliers to remove it. Threads are left-hand on the bolt. Watch for any shim washers behind the coulter on the bolt. Disc scraper will be sharp, so be careful.
Remove pin holding the monitor sensor & seed delivery tube & pull up out of the way. Using a 9/16 3/8 drive socket with a 2 inch extension, back out 2 bolts inside the "shoe" where they are bolted to the "arm" of the individual rows. Removal & reinstalling will be evident from this point. Use red Loc-tite on the hub cap rim when re-installing. Think I've covered just about everything-- we just replaced ours this year.
