You bought a REPAIR manual, and you're expecting it to tell you how to perform MAINTENANCE. Wrong tool for the job. You may as well be pounding nails with a pair of pliers.
Get the owner's manual. That will include the maintenance how tos that you're looking for, oil types, capacities, lubrication points, maintenance intervals... It's all in there.
There should be a round cover held on with wing nuts on the right side in front of the wheel. This cover should be on a 6-sided plate that bolts to the side of the tractor. Removing either will give you access to the hydraulic filter. You will lose a couple gallons of fluid.
If changing the filter doesn't fix the problem, changing the fluid won't help. You've got bigger problems.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
